Switching oil types question
Postby motorider200 » 07:01 pm Dec 10 2004
Hey everybody, I just switched from gearsaver to mobil 1 with the red cap and now my clutch has started to act funny. The cluch doesn't want to disengage all the way. I used to be able to start the bike in gear just fine and now I can't. It didn't start doing it until about 1:30-2:00 hours after the switch. I am clueless as to what might be going on. Should I just change the oil again with mobil 1? Or should i switch back to gearsaver? My only reason for switching in the first place was because I was at the auto parts store buying oil for my truck and saw the mobil 1 and thought I would give'er try and see if I like it. Any help would be great. Thanks, Braden
97 KDX200(225)- mine
01 KDX220- brothers
97 XR400- dads
motorider200
Has thanked: 0 time
Been thanked: 0 time
Postby skipro3 » 09:47 pm Dec 10 2004
Changing the oil twice will ensure you got the old stuff out. I use red cap mobil1 and it works great for me. I use the full quart.
There are a couple of things you might want to check:
1. Cable adustment. If it has streached any at all, then it may cause this type of problem
2. Cable needs lubing. A dry cable will also not work well.
3. Cable is binding up somewhere.
Go through the adjustment proceedure in your manual.
Good Luck and post back what you find.
skipro3
Has thanked: 0 time
Postby motorider200 » 10:23 pm Dec 12 2004
Thanks for the reply Skipro3, I changed the oil and adjusted the clutch some and and everything seems to be just fine.
01 KDX220- brothers
97 XR400- dads
motorider200
Has thanked: 0 time
Postby Indawoods » 10:28 pm Dec 12 2004
Mobil 1 all the way.... great stuff! :supz:
"People ate cows a thousand years ago for the same reason we eat them now. Cause they are easy to catch.We're not savages,we're´╗┐ just lazy. A cheetah could taste like chocolate heroin. But will never know. Those bastards are fast!!! "
Has thanked: 0 time
Been thanked: 20 times
Return to KDX General Q&A
Who is online
Users browsing this forum: Bing [Bot] and 13 guests
