Oil dripping from PV rod rubber boot?
AussieKDX200
Post by AussieKDX200 »
Hi guys
Noticed on my last ride a fair amount of spooge was dripping from the boot, as pictured:
It was enough to leave a buildup on the engine case below...
Is this something to worry about? Causes?
thanks!
Aidan
1997 KDX200R
AussieKDX200
Re: Oil dripping from PV rod rubber boot?
Edit:
I see someone else has the exact same issue a few threads down!
Some info on how to best check the seal/o-ring would be great. Is it straightforward?
Thanks
1997 KDX200R
throttleout
Post by throttleout »
Yours isn't near as bad as mine. I'm replacing the exhaust valve main shaft seal, and the sub valve shaft o-rings. Looks pretty easy. I'm a novice though....we'll see :partyman:
2000 KDX 200
RB carb mod
FMF rev, power core
Race tech gold valves
AussieKDX200
It's bad - I cleaned a lot of oil off the cases after my last ride.
Never an issue before, so I assume the seal has finally let go. Given it's happened so suddenly, is it more likely to be the shaft o-ring or the main seal?
1997 KDX200R
throttleout
I'm new to this so I couldn't tell you.
2000 KDX 200
RB carb mod
FMF rev, power core
AussieKDX200
Anybody?
1997 KDX200R
Tedh98
Post by Tedh98 »
I would only be guessing. Just need to pull it apart and find out for certain.
AussieKDX200
I guess either way it's engine out to access everything?
Given the issue is either the main shaft seal or the sub valve shaft o-ring (both on RHS of engine) is it possible to remove these two parts without pulling the head/removing the actual sub valves?
Cheers
1997 KDX200R
Tedh98
Post by Tedh98 »
The head definitely needs to be removed. Maybe the cylinder could be left on the engine, but I have never tried it.
I would suggest doing this the right way though and pull the cylinder. It is going to be so much easier that you will gladly pay for the base gasket. There is another seal on the other side of the head that you should replace since something on the other side is worn and leaking. And finally, the valves will likely be dirty or gunked up and could use a good cleaning.
IDRIDR
Post by IDRIDR »
How do we clean the valves?
2003 KDX 220. RB Carb & Head Mods. Desert pipe. She's a runner!
2006 KLX 250 w/351 big bore. A well-sorted dual sporter.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
AussieKDX200
Tedh98 wrote:The head definitely needs to be removed. Maybe the cylinder could be left on the engine, but I have never tried it.
You are right - do it once, do it right.
Just a shame to have to rip it apart though, as the bike is literally flawless otherwise. I checked operation of the PV recently looking up the exhaust port, and all seemed quite clean.
1997 KDX200R
3j3j3j
Post by 3j3j3j »
It was me who had the same problem awhile back. I cleaned the whole powervalve. I suggest taking the cylinder off. If only like another 6 bolts and a whole lot a easier
KarlP
Post by KarlP »
I don't think you can get the subvalve shafts out without taking the cylinder off. The frame is in the way.
You also can't get the main shaft out because the KIPS actuation shaft coming up from the lower end is in the way.
When you take that claw gear off the KIPS actuating shaft, be aware that it is LH thread and that you will break something down in the motor if you don't keep that shaft from turning while loosening the nut
'08 KTM200xc
KX100 for the boy
