1998 kdx 200
1998 kdx 200
Picking up my new to me kdx 200 ..what is a good ratio for the premix..synthetic or conventional oil?gear box oil..any thing else special I should do besides typical maintenance... Thank you
- Sullyfam
Re: 1998 kdx 200
I have a 2005 (same as your 1998) and we run 32:1 as it's what (if memory serves) the manual calls for. On gear box, I use Rotella 10w40 synthetic. Many use ATF (F type) with good success and I would argue one over the other. Key IMO is changing it when appropriate versus sneakin in a few extra hours.
Above all get a manual so you are not rollin blind and you can stay on top of the maintenance. These bikes are a ball and bullet proof if you treat them properly.
Welcome and I hop you find this site as useful and welcoming as I have!
- Sullyfam
Re: 1998 kdx 200
Sorry, I meant I would not argue which is better - Rotella/conventuals oils versus ATF. Many seem to have great success with either choice.
- diymirage
Re: 1998 kdx 200
i run klotz bean oil in my bike (mostly because it smells better then any other oil out there
i mix it 37.85 to one, that one i can mix 100 ml per gallon, and i can use a 350 ML waterbottle (filled with oil of course) to fill up my tank
for bottom end oil i prefer ATF type F, the bikes seem to shift nicely that way
Re: 1998 kdx 200
Thanks guys.picking it up soon I'll keep you posted.
1998 kdx 200
Picked up my new to me 98 kdx today.cleaning it up and changing fluids in her.thanks for the replays regarding oil info.any thing special with the cooling system I should do .thanks guys..
Re: 1998 kdx 200
I have a manual on the way to
Re: 1998 kdx 200
Shell Rotella 15w40 in the gear box.
Walmart Supertech mixed somewhere between 32:1 and 43:1 (I am mostly at very low rpms). 4 oz per gallon is 32:1. 3oz per gallon is 43:1
Sent from my iPad using Tapatalk
- kx200
1998 kdx 200
Ditto on the Walmart Supertech I run it at 50:1
http://www.kdxrider.net/forums/viewtopi ... 86&t=15331
Re: 1998 kdx 200
So how does that TC-W3 oil leave your power valves looking?kx200 wrote:Ditto on the Walmart Supertech I run it at 50:1
2002 KDX 220R
2003 KLR 650
2003 KLR 650
