HELP! SOS!
KDX_Johnny
HELP! SOS!
Post by KDX_Johnny »
I'm taking my suspension apart and I can't get the inner tube out! The manual says just pull it... I have been but she won't come out! I'm doing seals and race tech springs.
Just a square trying to ram myself into that circular hole...
Gotanubike
HELP! SOS!
Post by Gotanubike »
Hi, you have an '06 200 with conventional forks? I think you need to remove the damper rod first. A 27mm(29mm for E conventional forks) nut welded to the end of an "18 T bar to hold the damper from the inside. Loosen off the bottom to remove the valving. Damper spring and rod come out the top. Only then can they be separated. Check page 3-4 of my sig suspension thread
http://www.kdxrider.net/forums/viewtopi ... 5&start=60
1990 KDX200
Sullyfam
Re: HELP! SOS!
Post by Sullyfam »
Damper rod and the circlip under the dust seal that sits right above the fork seal.
JasonK94Z
Re: HELP! SOS!
Post by JasonK94Z »
Inner fork tube or damper rod?
2002 KDX 220R
2003 KLR 650
Re: HELP! SOS!
Did you remove the cartridge?
Did you remove the circlip?
Wow! I bet you beat it to death. :naughty:
KDX_Johnny
HELP! SOS!
I took it all apart properly. I just needed the dumb inverted 27mm. I have one now and will get back at it after work. Thanks guys!
