What's going on here?
2000 KDX200
What's the part that's leaking?
Leak Identification
Leak Identification
2000 KDX 200
RB carb mod
FMF rev, power core
Race tech gold valves
RB carb mod
FMF rev, power core
- Tedh98
Re: Leak Identification
I'm going to say you have either a leaking KIPS seal, like this one:
or the o-ring is leaking / missing on this shaft:
Whew. I thought it was going to be a tough one.
Look at Tedh98, pictures and everything! Great job!
Leak Identification
Awesome! Thanks Tedh98.
I'm totally new to these bikes, and I've only had top end experience with a PW50. So bare with me please.
I've been studying the manual (I have a sub to the manual ), and I have a couple questions.
If I check that the kips is opening and closing when the engine is revving, should I service the entire kips anyways?
Can I remove the head with the engine in the bike?
Can I replace the kips main shaft seal and the exhaust valve rod o-ring without removing the head?
Obviously if I have to remove the head I'll service the whole deal.
Much obliged
Much obliged
2000 KDX 200
RB carb mod
FMF rev, power core
RB carb mod
FMF rev, power core
Ok, now that I've got to look at my bike since my last post it doesn't look like I can get to the kips main shaft seal with out at least removing the main valve cover. In order to do that it looks like the engine does have to come out. Is that right? If so, should I go ahead and replace the piston rings while I've got it that far?
Thanks
Thanks
2000 KDX 200
RB carb mod
FMF rev, power core
RB carb mod
FMF rev, power core
Bump for advice....Thanks.
2000 KDX 200
RB carb mod
FMF rev, power core
RB carb mod
FMF rev, power core
Leak Identification
You can service everything at the top end without having to pull the engine from the frame. This includes servicing the KIPS as well as piston, rings, and cylinder. Just be sure to refer to the manual as you go. Be sure to properly support the KIPS shaft lever and be aware the nut has left hand threads.
