Reed spacer (and other)
frenche200
Post by frenche200 »
hello! well , I had heard speaking about kips cover spacer, torque ring, yet i discover the reed cage spacer...
what do you think about this type of spacer? do you think have the 3 spacer can be a good, or a not good idea?
thank you!! :grin:
i'm French and I don't speak English very well, so, please, excuse me :)
cornishwrecker220
Post by cornishwrecker220 »
These have been around for some time...mostly on road bikes...they can add bottom end or top end depending on if they are fitted before the reed cage or behind...
Boyesen rad valve & V-force reed blocks are thicker that stock cages hence the `bottom end` gains amongst other things.
frenche200
OK, I understand with VForce3 a reed spacer is not necessary and could be a bad idea?
it's very interesting because I will have a VF3 soon, thank you for sharing your knowledge! :grin:
