preventative maintenance
Posted: 10:47 pm Oct 07 2014
seems one of the most neglected parts on a used bike is the swingarm and shock linkage...i bought an 02 KDX220 in late sept...i knew the stuff needed replaced but had done it before with no problem...not the case with these..the main swingarm bearings crumbled to almost dust..the linkage bearings are actually peeling away a little at a time...it was easier to get an entire linkage assembly and way more cost effective...the linkage to frame mount bolt had also been loose, and "eggshaped" the hole in the frame...other than having an experienced welder/machinist fix that, i do the maintenance myself...shop rates are ridiculous...hoping i can get some feedback from anyone with the same model, good or bad....ive heard nothing but good things about it so far...thanks
