Hello guys
stripped my KDX and rebuilt everything. finishing touches are in progress. I forgot to take pictures of the hoses that are connected to the carb. Does anyone have information on this? Pictures / sketch / etc?
thanks
carb hose routing
Re: carb hose routing
The two on the sides of the carb as well as the one on the float bowl go down through a metal clip that hangs off the back of the engine, then from there down to underneath the bike by the shock.
carb hose routing
OK thanks I thought that was it.
What about the crank breather hose...is that supposed to connect to the airbox or somewhere on the carb??
I always run mine down the same way on all my bikes. just don't turn the bike off and let it cool in deep water, or it will/could suck water into the transmission
carb hose routing
The crank breather hose runs up to the little "hoop" on the left side of the air box.
carb hose routing
OK that's what that hoop is for!
I have had some road bikes where the crank breather(s) hook into either the carb or the airbox for emissions BS.
thanks again guys!
thanks again guys!
