Tire repair question
turtle
Post by turtle »
My last ride I got a thorn through the tire and ended up with a flat. The hole in the tire isn't huge or anything, and this might be a stupid question but I'm going to ask it anyway. Is there something I can / should do to repair the tire before I put the new tube in and put it all back together?
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
6 Riders
Re: Tire repair question
Post by 6 Riders »
Don't worry about the tire. Patch the tube with automotive patches and stuff it back in there.
turtle
Post by turtle »
:supz: Thanks!
Bill
Central IL
2004 KDX220R
diymirage
Post by diymirage »
turtle wrote:My last ride I got a thorn through the tire and ended up with a flat. The hole in the tire isn't huge or anything, and this might be a stupid question but I'm going to ask it anyway. Is there something I can / should do to repair the tire before I put the new tube in and put it all back together?
YES...pull the thorn out :lol:
canamfan
Post by canamfan »
I take a rag and stuff it in the tire and run it around to feel for thorns. It will snag if there is anything in there, better then using your hand, ouch!!! I have been putting tire sealant (slime) in my tubes cause I ride in a lot of hedge and locust thorns. It works well but if you need to patch your tube the slime oozing out make it difficult for the patch to stick.
morganid
Post by morganid »
Do patch kits work on dirt bike tubes? The only tubes I've ever tried to patch have been on bicycles. Twice I spent about the same on patches as I would have on a tube other wise trying to get it to work. I ended up buying a new tube anyway. Since I go to all the trouble to get the tube out, I'd just as soon replace it and not risk having the patch not work and tear it all apart again.
Bitteeinit
Post by Bitteeinit »
Melting the tube a bit (with extra rubber) works best, though it's not really possible "on the go".
turtle
Post by turtle »
:busted: Done!
Bill
Central IL
2004 KDX220R
kx200
Post by kx200 »
After about the 5th patch on a tube I will spring for a new tube. Have yet to have a patch fail :shock:
pumpguy
Post by pumpguy »
Old inner tubes are the dirt bike rider's friend. Cut them into rubber bands about 3/4" wide and use them to secure tools or spare parts like levers and such to any exposed frame tube. This trick has been used since prehistoric times.
morganid
Post by morganid »
pumpguy wrote:Old inner tubes are the dirt bike rider's friend. Cut them into rubber bands about 3/4" wide and use them to secure tools or spare parts like levers and such to any exposed frame tube. This trick has been used since prehistoric times.
Awesome idea. I've also heard of slicing the tube right in half long ways and tucking the new tube in side the old one an extra skin for the new tube.
