What size Screw / Bolt '03 rear fender?
TNKDX
Post by TNKDX »
Pretty sure the rear fender on my 220 is after market and it has 2 brass threads underneath behind the tail light for mounting something. I want to rig a license plate mount and attach to these bungs. The threads seem to be some crazy configuration and I cannot find any bolts/screws that will work. I have tried M6 x 1.00 and 1/4 20 and 1/4 28. The M6 and 1/4 bolts are the right size but the threads will not work. Any ideas??
Thanks!
canamfan
Re: What size Screw / Bolt '03 rear fender?
Post by canamfan »
Maybe m6 x 1.25
TNKDX
Post by TNKDX »
I thought about that but went blind trying to find one on the web I could order to try. Any ideas on a good source?
newbbewb
Post by newbbewb »
take the whole damn fender to the local hardware store and find one that fits. to my knowledge, there is nothing brass on a factory bike, so nobody here will know.
93 kdx200-Highly modified
89 kx125/kdx200E engine
Buelldustin@gmail.com
6 Riders
Post by 6 Riders »
Picture?
TNKDX
Post by TNKDX »
Here you go.. Any ideas would be appreciated. ImageImage
Sent from my SCH-I605 using Tapatalk
6 Riders
Post by 6 Riders »
I have those same mounts, so I'd assume stock fender. I just put a standard body bolt up into mine (same as shroud bolts). I had an extended licence plate mount on my bike.....Plate didn't last long and I ended up re-upping my tabs 3 months early so I could get a new plate. I ended up bolting my plate to the fender, just below the tail light and it has very little overhang or exposed edges. If you mount something to those holes and it gets hit by your rear tire, it's very likely that you will punch that tail light right off of the fender, essentially ruining your fender.
6 Riders
Post by 6 Riders »
OH, and because our bikes where made in a street legal version (in other parts of the world), there is probably a stock fender extension that bolts up right there.
6 Riders
Post by 6 Riders »
pumpguy
Post by pumpguy »
My plan is the same as yours, to mount a license plate bracket to those tapped bosses. Mine is tapped M6 X 1. Since those bosses are brass, there will be a little corrosion build-up that will prevent M6 X 1 bolts from screwing in easily. I would suggest you get yourself an M6 X 1 tap and run it into those holes to clean out the corrosion.
Good luck
TNKDX
Post by TNKDX »
Good idea Pumpguy, that would make sense. Will give that a try.
diymirage
Post by diymirage »
just look it up on the partsdiagram on Kawasaki.com
-1997 KDX 220 project bike
TNKDX
Post by TNKDX »
Pumpguy, you are da man!! Picked up a metric tap and die set on sale at Harbor Freight for $14.95 and I am in Bidness! It is indeed an M6 x 1.0 and smooth as silk now.
TNKDX
Post by TNKDX »
Thinking about getting one of these... http://www.fourstrokesonly.com/LicensePlateHolder3.html
TheJackRabbit
Post by TheJackRabbit »
that's the stock rear fender, my stock rear fender has the same configuration underneath
http://www.youtube.com/allthatstuff35 <--- some KDX videos here
I'm smarter than I act
