Stock forks
Stock forks
Are the adjustable? I don't really want to get into do a conversion mainly because the cost. My stock forks feel soft is there anyway of making them stiffer?
- scheckaet
Stock forks
check the suspension section, and yes they can be improved for cheap.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Re: Stock forks
country??
bike model??
bike year??
bike model??
bike year??
Stock forks
Hi admin
I am in the UK I have a 2002 kdx 220
Re: Stock forks
Thanks. What is your weight in riding gear? (in pounds, not stones!!)
Do you think the stock springs are still in the bike (no one ever changed them)?
There are compression adjusters under the rubber caps on the bottom of the forks.
Generally, the stock springs are too soft for most rider weights and a change to stiffer springs is what help most for most 1986+ forks.
- ICRage42
Re: Stock forks
If Im not mistaken you can get quite a lot of parts there especially for front conversion. Just do it don't waste the time on doing anything with those forks .......I redid mine or bought them redone....sprung for my weight but they just don't handle very well and suck up under ya if you ride hard enough. I put klx ones on mine and almost direct swap and holy smokes what a difference. Sorry but I feel stupid for investing in stock forks. If it wasn't for the fact that I could use the new front rim/tire/brake etc which was also all new I would of been out a lot of money. I had two other sets of forks and didn't do the swap because of sourcing parts just stayed with mine. Ive had two trips now on the new forks I don't know whats in them but I rode hard both times and wore myself out each time I was leary of things because normally Id be over the front forks. Not now.
Tuning those dam dang forks is a real pain too. Follow the guide and you get a good sense of where you need to be but in the end it just don't cut it. I spent three weeks of trying to tune mine in. Thought about going gold valves for em and them just said nah Im doing a conversion. I got them the best I could and it just wasn't enough......especially if I hit the buffet hahahahahaha Dam four pounds over because of extra steak........mmmmmm
Just do it and make ya momma proud on the whoops.
Re: Stock forks
So upgrading stock forks isn't worth it?! I also found mine soft despite me only being 190lbs or so in riding gear. I usually like soft suspension though. Any recommendations on springs/suspension websites?
- Gotanubike
Stock forks
I added extra preload to my springs and it made all the difference in the world. My brother does some machining so he was able to make these spacer tubes but you could also try stacking washers. I had the spacers made at 12.7cm, so 17mm of extra preload.
http://www.kdxrider.net/forums/viewtopi ... 19#p150019
1990 KDX200
Re: Stock forks
I have the USD forks. Would this still work with USDS?
