Replate or new cylinder time?
Posted: 02:47 am Jun 26 2014
by crs
Just checked the top-end of my new '99 220...
Thoughts please...
(If it does need replating and anyone knows somewhere good to do it in the UK, I'd appreciate the info'.)
Thanks.
Re: Replate or new cylinder time?
Posted: 05:23 am Jun 26 2014
by diymirage
I would say have it bored over 1.0 mm and replated
I had one of my 200 done by langcourt and was very pleased with the work and the level of communication
(I used their US facility but they actually started out in the UK)
http://langcourt.com/page2.html
since it looks like yours needs a rebore be sure to include the KIPS valves so they can grind the main valve for piston clearance
they should also have the piston you need in stock so just buy it from them and they will match the bore to the piston
im guessing your cost will be about 250 pounds for a bore, replate and top end kit
Posted: 06:56 am Jun 26 2014
by crs
Thanks for the advice and link - I've sent them an email.
Posted: 07:43 am Jun 26 2014
by Julien D
I'm not sure that would need a bore. I had one much worse off than that and langcourt did some weld repair and then plated back to factory spec.
Posted: 08:56 am Jun 26 2014
by crs
Langcourt have said they can replate to standard.
Posted: 10:39 am Jun 26 2014
by scheckaet
Julien D wrote:I'm not sure that would need a bore. I had one much worse off than that and langcourt did some weld repair and then plated back to factory spec.
+1
Posted: 12:47 pm Jun 26 2014
by fuzzy
Indeed, I believe Langcourt will bore out the plating, and replate for no cost. Overbore is additional, and required fee for gouge repairs, etc.
Posted: 05:56 pm Jun 26 2014
by diymirage
I guess if you weld enough material to bore it back down to stock bore, that's an option aswel
Posted: 09:43 pm Jun 26 2014
by Julien D
They won't weld that. They'll just cover it with plating. Mine had some huge gouges and chipped ports from a grenaded piston, hence the welding. That cylinder is fine, it's factory plating is just shot.
Posted: 10:10 pm Jun 26 2014
by diymirage
cool
not like the factory plating is all that durable anyway
