I have a 79 KDX 400 that is not getting any spark when i kick it. Does anyone know how to check thru this so that I can figure out what is causing this? I wanted to check from the motor, to the CDI box, to the ignition coil, but dont know what should have voltage where. There arent that many wires to test on this bike since its so old, but i wanted to check to see if anyone has any info on this.
Thanks!
Not getting any spark
- Jaguar
- Country: Paraguay
First try a different spark plug. Hold the plug onto the head while kicking it over.
If no spark then make sure the screws holding the stator coil onto the cases are tight. They are the ground path for the circuit.
Next disconnect the CDI and put an AC voltmeter on to the wire from the stator coil and to chassis ground.
There should be around 400 ohms there if your meter is set to read resistance. If it reads infinite resistance then the stator coil is burned open. If it reads less than 250 ohms then the stator coil has a short in it.
Kick it over and see that you have at least 30 volts AC there.
Next connect the CDI but disconnect its output wires going to the high voltage coil. Hold them (touching the metal connectors) and kick the engine overly (slowly at first and then faster) to see if you get any little jolts of electricity. The output voltage is just a very quick duration spike which is why it is hard to read on a meter. If you get mini-jolted then the CDI is good.
If everything else is good then that leaves the high voltage coil and spark plug cap.
You can try screwing the cap farther onto the high voltage wire to make sure it is connecting good.
Make sure you can feel the spark plug snap into place into the spark plug cap when you are pushing the cap onto the plug.
Re: Not getting any spark
Man i really appreciate the reply, i am going to try this later on and see what i can come up with. i will get back to you with what i find
