Trail tech question
Trail tech question
Hi, Just purchased a trail tech endurance & was wondering the best way to set the front wheel size into the system, front wheel is from a KX (2001) can anyone estimate the size or does it need to be bang on, Is it best to measure the wheel & tyre & roughly what figure should I come up with in mm? Any thoughts or advise would be great!
- IDRIDR
Re: Trail tech question
See trail tech instructions. There are several ways. One easy one is to mark the tire with chalk or something, put that mark down and mark pavement, roll one revolution and mark pavement again, measure between pavement marks.
If you want it spot on, I think a gps unit is a good way to go for comparing speed or mileage.
2003 KDX 220. RB Carb & Head Mods. Desert pipe. She's a runner!
2006 KLX 250 w/351 big bore. A well-sorted dual sporter.
2006 KLR 650. Mostly stock.
2014 Suzuki DL1000.
2014 Suzuki DL1000.
If you need it 1 inch =25.4 MM
