KIPS return spring
KIPS return spring
On my KDX 220 the KIPS does not seem to return.
I have opened the left cover and turned the 10mm bolt. Looking through the exhaust port everything seems operational.
Problem is the shaft turns very easy but does not return automatic. Feels like a spring somewhere is missing.
With the bike running the shaft turns as it should but I have to assist it to the closed position.
Where is the spring located that should return everything to the closed position? Top side of engine or below at the govener?
Re: KIPS return spring
It is all in the governor assembly. It is likely that the pin at the bottom that rides in the governor was bent or broken while the left hand nut on top of the pawl gear was being removed.
- scheckaet
KIPS return spring
that would be my guess too, that or the valves are badly gummed up (less likely).
Check my sig for newb info
replace that stock piston on that 220 while you're at it ...
welcome to the site.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
That means opening the sub clutch cover? (or whatever it is called). Read a lot and watched some videos about that left hand threaded nut.Julien D wrote:It is all in the governor assembly. It is likely that the pin at the bottom that rides in the governor was bent or broken while the left hand nut on top of the pawl gear was being removed.
Will the valves still operate with a bent or broken pin in the governor? The flapper valve and sub ports do open as the I rev the bike. They just do not return properly.
KIPS return spring
Doubt the valves are gummed up. They operate easy when taking a 10 socket to the left side of the shaft.scheckaet wrote:that would be my guess too, that or the valves are badly gummed up (less likely).
When doing the same on my 200 I feel the spring loaded resistance which I do not feel with the 220.
Thanks for the newb info link. Have already done most of that. (Edit: Trying to sort out the carb. Seems previous owners went way off with needles and jets)
I have no doubt that the piston on this one has already been replaced. Just trying to find out from the previous owner/s when last it was done. Might just replace it again if I can't track them down.
Possibly, If it's bent and catching. If it's broken it likely would not operate at all. If the gears operate smoothly without the pawl gear in place, the problem certainly lies somewhere in the governor. Removing the inner clutch cover is not a big deal. It helps if you remove the rear brake lever first. It will be pretty obvious how that stuff works once you get a look at it.
KIPS return spring
You can tell if it is the governor or gummed up valves by removing that pawl gear and operating the valves from the left side.
I had one of the shafts for the subports get really stiff in its bore and the valves would close slowly or not at all.
You sure can tell from the way it runs when those valves don't close.
'08 KTM200xc
KX100 for the boy
KX100 for the boy
KIPS return spring
I removed the gear on the right hand side. (the left handed thread nut)
Turned the shaft clockwise:
- The first few mm was loose.
- Then I could feel the spring tension.
- Then it slipped past whatever is now loose (can turn loosely for about 1/4 turn)
So will have to remove the right cover to get access and see what is bent/broken/misaligned.
Been reading up a bit. Can I do it as follow?
- Drain water and oil.
- Keep water pump and clutch cover in place
- Remove the secondary clutch cover with the other two covers in tact?
KIPS return spring
Ok so I tried. Yes you can remove the right cover including the water pump and clutch cover in tact. Easy job. Just one of the clutch cover bolts that goes straight through also to be removed.
The culprit was a bent pin. Will see if I can post a pic later. But in this case it was bent closed. In other words the previous guy that worked on it did not support the shaft when he tightened the left handed nut.
Bent it straight and back on and working perfect.
- scheckaet
KIPS return spring
Do NOT use this pin, it WILL break and cause a lot more damages when the pieces are jumping around...Piet wrote:Bent it straight and back on and working perfect.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
KIPS return spring
+10 Once it's been bent (and now rebent) it is going to break and then you risk much more damage. replace it.scheckaet wrote:Do NOT use this pin, it WILL break and cause a lot more damages when the pieces are jumping around...Piet wrote:Bent it straight and back on and working perfect.
KIPS return spring
Please let me know if you can see the image below.
- scheckaet
KIPS return spring
yup it's toast.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
I wouldn't risk it. That little guy can cause a lot of damage when it's bouncing around in there.
Sent from my HTC6500LVW using Tapatalk
KIPS return spring
Thanks for the feedback. Love the knowledge on this site.
Have ordered a new one. Only R100 (about $10). Probably expensive compared to US prices.
Such a struggle to get parts around here. Something as simple like the needle Kawasaki don't have stock and have to import.
