Stock Headlight Aim???
Posted: 11:34 pm Feb 13 2014
by morganid
Even though it's still winter in Idaho, I ride when I can. For now that means on the streets back and forth to college classes. But it gets dark early. I have discovered that my headlight is GREAT for checking the trees for monkeys and not so great at checking the road for ice patches. CAN THE STOCK HEADLIGHT OF A 2003 KDX 220 BE AIMED AT THE GROUND INSTEAD OF THE TREES? Seeing the road would be nice.
Thanks.
PS. Also why is there not a 220a forum in the Model Specific Forum section?
Re: Stock Headlight Aim???
Posted: 06:30 am Feb 14 2014
by royadams
The screw under the headlight is the adjuster. Loosen it it will lower the beam, tighten it will raise it.
Posted: 06:57 am Feb 14 2014
by spl383
I bought a new longer screw and a stronger spring for mine.
Posted: 03:05 pm Feb 14 2014
by TheJackRabbit
there is no 220 section because the H series 200 and A series 220 are the same with the exception of the topend of the motor
Posted: 01:06 am Feb 15 2014
by Julien D
Because it isn't any different than any other KDX manufactured since 1995?
Posted: 07:11 pm Feb 16 2014
by morganid
TheJackRabbit wrote:there is no 220 section because the H series 200 and A series 220 are the same with the exception of the topend of the motor
Ah. I see. Thanks
Posted: 07:12 pm Feb 16 2014
by morganid
royadams wrote:The screw under the headlight is the adjuster. Loosen it it will lower the beam, tighten it will raise it.
Awesome. I found the screw walking by my bike. When I get some time, I'll play with it.
THANKS!
Posted: 09:56 pm Feb 18 2014
by morganid
Found the screw and adjusted it. The previous owner had it 100% screwed in
I think that squashed my spring flat. I think I'll be getting another spring in the future.
