Needle Bearings
Needle Bearings
Ok so I finally go my shock serviced and put back in the bike. But today while I was in the garage I found a small needle bearing on the ground can a bearing just fall out when you are removing the shock and putting i back in the bike? Confused here because the bearings are fairly new in the linkage.
- kx200
Needle Bearings
grease is all that hold them in place
Re: Needle Bearings
Yep, gotta take it back apart.
- ICRage42
Needle Bearings
be sure to check them all to make sure no gaps. You could of dropped more then one. Yea just grease usually holds em in place.
- Gotanubike
Needle Bearings
You can prevent that by putting the sleeve and bolt back in the linkage until you put the shock back in.
if you need to buy a new bearing might I suggest pivot works, they are $3.49
http://www.pivotworks.com/ProductInfo.a ... m_id=52099
1990 KDX200
