question for guys that have done kx fork conversion ( ride h
Installed 02 kx front end on my kdx , just wondering what your forks measure above the top tripple , mine are @ 5/8 inch to the top of the tube to the top of the clamp , cant decide if im in the BALL PARK or not . Appreciate any info .
Re: question for guys that have done kx fork conversion ( ri
5/8" might be a bit much, but I think in the ballpark
I would set the rear sag "by the book", say race sag at ~1/3 of travel or 110 mm, I believe.
The front height probably won't be right and you'll likely need to move the forks up or down in the triple clamps until the front/rear attitude feels right. An 1/8" move makes a big difference and can be felt right away.
I usually take the bike out to a loop of typical trail that takes 3-4 minutes to run and make fine adjustments to the rear sag from there.
You'll know when you hit the sweet spot, all of a sudden it will just feel on the money. Be carefull because a small change in front fork height or rear sag makes a big difference.
There is probably more information in the fork conversion section.
Have fun
Have fun
'08 KTM200xc
KX100 for the boy
KX100 for the boy
- G22inSC
My forks are about 11/16" (or about 18mm) up in the clamps if I remember correctly. Check out my gallery and look in the KX fork conversion sub album. I think I had a couple pics showing the factory original fork measurement and the installed KX measurement.
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
'08 Kaw KX65 (Sold)
Gallery
Mine are 7/16" from top of upper tripple to top of fork. Rear sag is set at a normal setting ( I have a racetech spring to match my weight). Running a 120/90-18 (110 basic height). Bike works awesome, no real headshake at speed and still has good slow speed turn in. I had them slid up further in the tripples probly closer to your measurement before and it was ok, but handles much better with this current set up.
