Would a 1995 KX125 MOTION PRO VORTEX THROTTLE with its cable work on my KDX200 as a quick turn throttle?. Any help will be appreciated.
Roger
2006 KDX200 question
Re: 2006 KDX200 question
I believe it will. I used an OEM '95 KX125 throttle assembly with the stock KDX cable on my KDX when I put '95 KX forks on it. As I recall, the KX cable was a little short because of my enduro computer. It is a shorter turn and I thought a better mechanism inside. The pull was much smoother than my worn out KDX assembly.
Alright thanks!. I thought if you change the KDX throttle for the KX one you had to use a KX cable, but I guess not. I'll order the KX one
Thanks again,
Roger
Thanks again,
Roger
