What gearing do u guys like best 200?
- Actionman
i thought i had 13/52 because the po told me so, and i found first too low for my taste and only topped out at about 56mph. Way too quick to hit the redline in the woods for me. Well, i found out i had a 50 tooth after i had bought and installed a 14 tooth countershaft sprocket! The odd thing is- i love this ratio. To me, first is way more useable and it added about 6mph to the top end. Im a fan of this gearing! I notice a lot of u guys run lower ratios; anyone ever try the 14/50 combo that im using?
2002 KDX 200
Re: What gearing do u guys like best 200?
That 14/50 ratio is the same as the 13/47 ratio used on the early E-series bikes. You're just carrying more weight around with the larger sprockets and longer chain.
I'm currently running 13/48 because RMATV sent me a 48 rear when I told them I wanted the stock gearing. The only they have ever messed my order. Next time I will be back to the 13/47.
- Actionman
I like it! I thought 13/50 was a mess because first was way too low. Felt like it to me anyway.
2002 KDX 200
- 6 Riders
I run 14/47 on both my E & H bikes, love that ratio. Over all I find the bike very manageable on open trails and in the tight single track...even run the Dez with that gearing.
- Actionman
I was under the assumption that a larger countershaft sprocket was better due to the less severe angle of the chain? Next time i regear i will indeed go smaller, but i tell you what i love the way my bike runs with this setup. To me, it makes the gearspread as smooth as butter, but i may not be the best judge of these things, lol. It SEEMS pretty nice.SS109 wrote:That 14/50 ratio is the same as the 13/47 ratio used on the early E-series bikes. You're just carrying more weight around with the larger sprockets and longer chain.
2002 KDX 200
I run a 13/52. I love it. It would climb a tree if you could keep it hooked up. lol
Its not rocket surgery...
- Actionman
lordy! Too low! lolpatricktjms wrote:I run a 13/52. I love it. It would climb a tree if you could keep it hooked up. lol
2002 KDX 200
- rbates9
I have 12/48 on one rim and 12/47 on another. I will probably go with 13/50 or 52 next time.
- Velocity_Stack
12/52 here.
I like slow technical woods riding.
- Actionman
Top speed.......14mph! lolVelocity_Stack wrote:12/52 here.
2002 KDX 200
- Velocity_Stack
Lol all you want, I use to be young and have the need for speed, but now it's all about enjoying the ride.Actionman wrote:Top speed.......14mph! lolVelocity_Stack wrote:12/52 here.
I'm not out to set speed records.
I enjoy the ability to make technical maneuvers at a slower pace.
After all, I am riding with my 10 year old daughter on her XR70R.
Not much fun for her if I run off and leave her.
I was just sharing what seems to be working best for me, in my surroundings and limited riding areas.
- Actionman
Im old too! lol. Just having fun with you. My real problem with that low of gearing is that even 13/50(my original gearing) made first too low. I always felt like I needed a gear between first and second. Its personal preference I know, but I always was either overreving on hillclimbs or lugging in second too much. I enjoy stock gearing.
2002 KDX 200
Velocity_Stack wrote:Lol all you want, I use to be young and have the need for speed, but now it's all about enjoying the ride.Actionman wrote:Top speed.......14mph! lolVelocity_Stack wrote:12/52 here.
I also am riding with my 6 year old on his atv so most of the time i spend on the bike is at about 11mph. its nice to be able to accidentally dump the clutch in the woods and not stall the bike though.
