Any other carbs fit my 86 KDX 200
Ford Junky
Post by Ford Junky »
I've been tryin to git my 86 runnin better, and found out I have the wrong carb. My bike has a Mikuni V20, but from what I read it should have a VM34. That would explain why it wouldn't pull at anything over 1/8 throttle. I havent been able to git hold of a 34, so im wondering if anyone knows what other carb I could run that I might be able to find.
Roadhazardguy
Re: Any other carbs fit my 86 KDX 200
Post by Roadhazardguy »
Any of the 88+ keihin 200 carbs should work but I think you'll need an 88 intake boot. Someone correct me if I'm wrong.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
sarrant
Post by sarrant »
I believe you have the stock carb, but you probably want to measure to be sure. Some of the Mikuni VMs had some stampings on them (like for example V20) which were for specific config identification.
sarrant
Post by sarrant »
Yeah, just confirmed (sorta).
Picture is from ebay auction from an 87 KDX. Note the stamp.
Ford Junky
Ok, thanks. Thats real good to know. I sure appreciate the help, I dont have much bike experience, most of what I do is automotive or heavy duty. Now I'm back to lookin for a needle jet for this carb.
sarrant
Post by sarrant »
The Mikuni round slide is probably the most common motorcycle carb ever built. You shouldn't have any problem getting a variety of needles at any decent parts shop
Ford Junky
The needle itself isnt hard to find, your right, but the needle jet seems to be elusive. Looks like someone tried to turn mine out at some point instead of pushing it out. When they did that they damaged it to where the needle cant meter fuel property.
sarrant
Post by sarrant »
The VM needle jets are also completely commonly available, but you could always go to a big Mikuni distributor, like Sudco if your local guy won't get it.
fuzzy
Post by fuzzy »
Yep, that should do it, and a throttle/cable.
