rim finish options
- diymirage
rim finish options
hey guys
I just got done tearing apart the winter rims for my buddy bike and I have a question
the spokes are rusted pretty badly and im planning on sticking the whole rim in the sandblaster to get the spokes and hubs nice and clean
I am then planning on shooting some paint over them to keep em looking nice
hubs, spokes, no problem BUT the rims are polished aluminum and im not sure how to treat them
If they get "scuffed" by the sandblasting (not full on but by being in the cabinet while it is in use) will I be able to hit them with a scotchbrite pad or some OO steel wool to get the shine back ?
or should I polish the lips up a bit and tape them off before sticking them in the cabinet and then just painting the centers off them ?
im not going for show stoppers here, just winter wheels for the buddy bike but I want it to get as good as I can
-1997 KDX 220 project bike
Re: rim finish options
"will I be able to hit them with a scotchbrite pad or some OO steel wool to get the shine back ?"
noooooope
break out the tape
noooooope
break out the tape
If the spokes are rusted that badly I'd just replace them. Cost of new SS spokes is worth the piece of mind for me, plus it makes cleaning up the hub and rim a LOT easier when its all apart. Building a wheel is not difficult. But then I guess I fall into Batesys camp
Soda blast everything, paint the spokes silver, wet sand the outer lip of the wheels with 400 grit then clear the rims/ hubs and put them back together.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
- rbates9
+.5Roadhazardguy wrote:Soda blast everything, paint the spokes silver, wet sand the outer lip of the wheels with 400 grit then clear the rims/ hubs and put them back together.
Try to soda blast every thing still assembled and see what they look like. It wouldn't hurt to try a "magic eraser" on the rim to get the crap off and see what is still there. The spokes should be stainless so painting shouldn't be required.
- Postigo
Look for spoke coats at ebay.
- diymirage
rbates9 wrote:+.5Roadhazardguy wrote:Soda blast everything, paint the spokes silver, wet sand the outer lip of the wheels with 400 grit then clear the rims/ hubs and put them back together.
right now, that's the plan
I was a little surprised the see the amount of rust on the spokes but it came off pretty easy with a wire brush but I just don't feel like doing all that work by hand
as for replacing the spokes, I don't think that is necessary, it doesn't look like the rust penetrated the spokes very deep and I don't think the structural integrity is damaged
Postigo wrote:Look for spoke coats at ebay.
you mean those straws you have wrapped around your spokes?
I stopped doing that when I was 7
(actually did look them up and considering getting them in green or purple, but only AFTER blasting the rust off the spokes)
rim finish options
You'll need an etching for all the aluminum bits or it will peel pretty quickly. The best option is to have it powdercoated, painted aluminum if done correctly works OK but still not very durable.
I deal with this on customer snowmobile parts all the time. Do a little googleing about painting aluminum.
It's about a boat but this goes over the process pretty well http://voices.yahoo.com/how-properly-pa ... tml?cat=11
- Postigo
It seems that you going to start doing it again. Loldiymirage wrote:rbates9 wrote:+.5Roadhazardguy wrote:Soda blast everything, paint the spokes silver, wet sand the outer lip of the wheels with 400 grit then clear the rims/ hubs and put them back together.
Another tip on the wheel restoration is to use some blue magic paste on the rims and some eagle one mag cleaner on the hub.
- diymirage
not planning on separating the hub from the rim so the mag one cleaner is out of the question
I started today with a scotchbrite pad on the rim, that came out looking ok
I will tape off the outer part of the rim and then soda blast everything else and paint it silver
while cleaning them I cam across this though
i'm thinking of cutting a groove on the inside of the crack and laying a bead in there, then grinding that down to almost smooth again and I should be good right ?
Yeah my rear wheel on my atk is welded on both sides and its fine. A lot of people say that's a big no no but I've put a lot of miles on a front wheel that was cracked worse than that and also on both sides but running a welded rim will definitely be better than just leaving it. They all crack at the original welded seam eventually so I would just weld it and keep an eye on it.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
- Postigo
don't need to remove the spokes to clean the hub with the mag cleaner. Use an old tooth brush and avoid contact with the rim and you will see how good it looks after the cleanup. To clean the spokes you can use a scotchbrite with soapy water to remove the rust and dirt.diymirage wrote:not planning on separating the hub from the rim so the mag one cleaner is out of the question
rim finish options
My 95 200 rescue had fairly stained spokes from the PO. I don't know what did it but it would not come off.
So I put my big boy panties on and tore the wheels apart and cleaned each individual spoke as best I could, cleaned the hubs and painted them green, I used Grabber Green engine paint. There are a couple of pictures of another bike done the same way in another thread above this one. I'm too lazy to learn how to post pictures!
Some may not like what I did to the spokes but I do. While the wheels were apart I painted the spokes black like the KTMs have been recently.
Relacing the wheels and truing them was time consuming and a bit frustrating at times, but all in all not that bad.
I don't know why it would be a no no to weld the rim they usually crack where the factory welds them.
- diymirage
Well, thanks for all the advice guys
I taped up all but the center inch of the rim and sandblasted everything that was left exposed
I then painted the hud, spokes, nipples and that center inch with silver rim paint
Once the paint dries I will remove the tape and have the crack welded
Then I will put down a few coats of clear
Ill post some pics once the tape is off
- rbates9
The recommendation for aluminum is to SODA blast them NOT sand blast them.diymirage wrote:Well, thanks for all the advice guys
- diymirage
honoutly Batesy, I have no idea what medium I used
we have a blasting cabinet at work and I used what ever was in there
seemed to work out allright though
- KDXohio
Should you use coke or pepsi?rbates9 wrote:The recommendation for aluminum is to SODA blast them NOT sand blast them.
