Flywheel magneto compatibility
KDXsg
Post by KDXsg »
Hi, anyone knows if the E series flywheel will fit a H series KDX? or any anyone helpful can provide some dimensions (length and diameter) of the H series KDX200/220 crankshaft (flywheel magneto side).
I am trying to fit an E flywheel (which I have) to my KDX200 which uses a KDX220 crankshaft.
Part number shows they are different, but they really look identical. Both uses the same woodduff key and securing nut. Many thanks in advance.
A true KDX customizer!!
De250r
Re: Flywheel magneto compatibility
Post by De250r »
Bolts right up
Sent from the back woods of vt via patchy Internet
Live free and ride hard
KDXohio
Post by KDXohio »
Difference is likely weight or something very small
