89 KDX200 rear brake rotor size and best aftermarket one?
Gotanubike
Post by Gotanubike »
Title says it all. Need a rear rotor for my KDX200 E series. What size should I b loking for and does KDXrider recommend? thanks!
1990 KDX200
KDXohio
Re: 89 KDX200 rear brake rotor size and best aftermarket one
Post by KDXohio »
I usually use EBC for all my braking needs they've got good rotors as well as pads I'm not sure on size but I think the kx125 rear rotors from 89-02 are the same as the E series kdx
Gotanubike
I'm gonna give one of these bad boys a go. If it fits, I'm happy. My current rotor is one more hard brake away from splitting in two pieces!
1990 KDX200
KDXohio
Post by KDXohio »
Dang 16$ sounds pretty good let us know how it turns out!
Gotanubike
The Chinese disc brake came in today...looks pretty good. It even has the rounded seats for the mounting screws.
1990 KDX200
