Calling Slick Nick. Help pls.
KDXsg
Post by KDXsg »
My rewound lighting coil off my KDX200SR model doesn't seem to work when I installed it.
What could have happened? I am getting frustrated.
I have checked/done: 1) scrape off the tips before soldering
2) followed the direction of the stock coil
3) epoxy the coil wraps
4) coil not hitting the flywheel
5) checked all connections again for continuity with a meter. Meter showed
0.06 ohm of resistant. measured from the tip of the yellow wire to the start of coil.
What could have happened or done wrong? Any help welcome.
A true KDX customizer!!
Re: Calling Slick Nick. Help pls.
Measure resistance from the yellow wire to black across the coil to make sure you don't have an open or short in your windings, should be 1.6-3 ohms depending on the gauge you used. Also look at the voltage on the yellow wire with engine running (and regulator connected) you should be seeing 8-16VAC. Make sure your light switch is on too. If it worked before you rewound it, then likely the problem is there.
KDXsg
Post by KDXsg »
Many thanks bufftester. will check again.
I suggest the same as above. Look for a short in the coil itself.
hadfield4wd
Post by hadfield4wd »
Slick Nick. I can't seem to find where to PM you. anyway I'm told you might know if a KDX rear wheel might fit a '98 KLX300R
'85 KL 600 my big dual sport
'02 Honda Rancher SQ (Sport Quad) big bore for my wife
'03 Honda Rancher Stock for my daughter
'99 Yamaha Breeze for my youngest son
'89 RM125 for my 14 year old
'99 CR250 Chassis with '90 KDX200 motor (Hybrid Woods Weapon Project)
If it's coming off an H or 220 (or a 250) its almost a direct bolt on. The only difference is the KLX right hand collar is 20mm instead of the 22mm on the KDX. You can either cut the KDX one down, or if you already have the KLX just use it's collars.
hadfield4wd wrote:Slick Nick. I can't seem to find where to PM you. anyway I'm told you might know if a KDX rear wheel might fit a '98 KLX300R
The part numbers for the hub etc are the exact same. Should bolt right up...
