Pivot Bolt broke
Posted: 10:26 pm Jun 24 2013
by mohawkman2
On my 2005 KDX 200 the pivot bolt broke off its purpose was to keep the rear brake pedal in place. How to I remove the bolt that is broken off?
Re: Pivot Bolt broke
Posted: 04:34 am Jun 25 2013
by diymirage
is there room to get a pair of vicegrips on after you remove the pedal ?
if not bolt extractors might work, you drill a small hole in the bolt and insert the extractor, which kind of looks like a tap but with reverse threads
as you thread it into the hole (in reverse) it grips and eventually gets so tight in there it you will start unscrewing the bolt
Pivot Bolt broke
Posted: 10:21 am Jun 25 2013
by Dekon
You could also try left handed drill bits. I had never heard of these until I needed a broken bolt taken out of a clutch basket. A friend came over with them, center punched the bolt and started to slowly and carefully drill the bolt. The bit caught the bolt and backed it right out. He said it works about 90% of the time. Needless to say, after he left, I went and bought myself a set.
Posted: 11:41 am Jun 25 2013
by K50X200
Ditto on the left-handed drill bits
