Idle question
Idle question
Here is a little problem I have seemed to come across. When I first try to fire my bike up cold, it will start and run for like 2-3 seconds and stall. It does this three or four times in a row, then it seems to idle fine. During this time, if I blip the throttle to keep it running, it stalls also. Also, if it is not warmed up, it has a slight bog off the bottom. Once warmed up it starts, idles, and runs fine. I have rejetted it and it rips when it is warmed up. Should I adjust anything or leave it as it is?
Idle question
That is the nature of a cold bike! Sounds completely normal to me. BTW, are you using the choke?
Idle question
Yes, using the choke. Sorry I forgot to mention that important piece of information.SS109 wrote:That is the nature of a cold bike! Sounds completely normal to me. BTW, are you using the choke?
- ICRage42
Idle question
id say cold tbh
Mine runs like a raped aped after gettin it warmed up. Whats the problem with a waitin a few? Not to sound like a tard or rude but sounds like you wanna hop on and whalla.
Jus sayin
Jus sayin
Re: Idle question
Oh, I don't mind waiting a few, just was wondering since the CR250 I had, once it was started it would never die like the KDX does. I was just wondering.
Idle question
Try without the choke at all and see if there's a difference. Hold throttle cracked a hair and kick it without choke. Bet it'll stay running.
- rbates9
Idle question
When mine is cold the choke needs to be turned off as soon as the bike starts to get it to idle.
