HANDLEBARS AND MOUNTS
Posted: 01:10 pm May 13 2013
by meccanj98
I am trying to upgrade my bars to 1 1/8 pro tapers. What mounts should I go with? I called pro taper and guy didn't have an answer. Could anyone please show me their set ups? I would also like to move my mounts forward more. I feel like the bars are to close to me. Is that possible. My bike is a 95 KDX with stock mounts! Thanks for any help.
Re: HANDLEBARS AND MOUNTS
Posted: 01:29 pm May 13 2013
Posted: 01:40 pm May 13 2013
by meccanj98
Does anyone have either pro taper woods bends? If so how are they?
Posted: 02:00 pm May 13 2013
by meccanj98
Or a Renthal set up?
AFTERMARKET BARS AND MOUNTS ON A 95 KDX
Posted: 04:06 pm May 13 2013
by meccanj98
Does anyone have aftermarket 1 1/8 bars on there bikes? How did you mount them? I spoke to Renthal and Pro taper and both said their mounts won't work. Help Please!
Posted: 04:40 pm May 13 2013
by rbates9
Posted: 05:20 pm May 13 2013
by cornishwrecker220
i run `enduro engineering` billet mounts on my 220, they raise the bars & also move them forward too, these items replace the OE rubber mounted bar mounts, i have also installed billet cones rather than the rubber ones.
Posted: 07:02 pm May 13 2013
by SS109
RMATV has some bar adapters/risers that will work.
http://www.rockymountainatvmc.com/p/43/ ... r+adapters I use the standard rider only version and they have held up great so far.
Posted: 08:27 pm May 13 2013
by tirebiter
I also run the Enduro Engineering mounts that cornishwrecker mentioned.
If your a stand up or taller rider, you solve two problems at once-
https://shop.enduroeng.com/cgi-bin/comm ... key=23-602
Crappy pics, but you get the idea..
Re: AFTERMARKET BARS AND MOUNTS ON A 95 KDX
Posted: 08:38 pm May 13 2013
Why would they not work?
Posted: 08:46 pm May 13 2013
by diymirage
i would imagine any 7/8th to 1.1/8 converter/riser should work just fine
they bolt on just like the caps on your regular handle bars do and then the bigger ones just bolt into those
i run a set of pro-taper like these but i also have a KX front end
http://www.ebay.com/itm/ProTaper-1-1-8- ... 0679157454
(dont worry Batesy...i got a much better deal than that)
Posted: 01:29 am May 15 2013
by gwynfryn
I used renthal mounts, standard H forks and pro tapers. Didn't want them higher than stock.
Posted: 12:22 pm May 16 2013
by potosi joe
I am using the Pro Taper mounts they work fine.
Posted: 09:25 am May 18 2013
by kashola
I have some of the generic adapters. They allow you to run 1 1/8'' bars, plus raise them a little bit.
