need help with wiring
i have a 1993 kdx 200 and tore it all apart to fix the shifter shaft and other miscelaneous parts inside also had the frame redone in black and metalic silver. the only problem i am haveing now is the wiring i cant figure out where it all goes and i have looked online but no help there either. also i have no headlight or tail light just the wires for a headlight and switch. so any help with this would be much appreciated thank you very much
Your manual doesn't say?
I don't want to make the mistake of assuming similarities between KDX versions, although I would guess they are pretty much the same...but I don't KNOW!
Does your bike have an AC regulator, or was that offed, too?
What color are the wires from the lighting coil?
Are you putting on any lights? If no, then forget about the AC regulator part. You won't need it.
