I got this clutch perch,what is it?
GKBO
Post by GKBO »
Was on a set of bars I picked up for my 86 200 project.Would like to know if it's a Kawasaki perch as I suspect it is as the bar had a battered lime green grip on it.Or is it something else?Make finding a lever easier if I knew what it's from.
Doesn't look an OEM Kawasaki perch I have ever seen. As long as it works is all that matters as they are fairly universal.
GKBO
Post by GKBO »
Yeah cruising around KDX200 on eBay yesterday I seen some pretty nice aftermarket perches.Like the idea of a spilt mount perch.
I went with an MSR AOI perch/lever setup and love it. IIRC, it was about $30.
I think it would be worth your time to just buy a new clutch perch and lever. By the time you figure out what you have it might cost more for a lever then a new set up. And the perch you have looks like it is either missing the cable adjuster or the screw from the side is how you would adjust the cable. If it is the screw then that would reduce the lever travel as the clutch wears or the cable stretches. And that would be bad.
GKBO
Post by GKBO »
I agree rbates,a member is sending me some stuff so I asked him if he had a perch & lever.
