Buying a KDX... one piece at a time
Re: Buying a KDX... one piece at a time
Postby Thedude1973 » 07:00 pm Jan 03 2013
JoKDX220r wrote:Have you think about building an hybrid instead ?
Yes, I've definitely thought about a hybrid. But honestly, that's probably too ambitious for me. I don't know how to weld, not to mention everything else that comes with that kind of project.
Dude...
Thedude1973
Has thanked: 0 time
Been thanked: 0 time
Postby FORCON8541 » 09:48 am Jan 04 2013
WIth that much responsibility at home I can only try to imagine what its like. You cant be selfish, especially when you have a family, and go out and drop 5-10K on a bike. I just dont want to hear that you spent 3K on a 1500 bike when its all said and done.
I didnt read all the posts and dont know how far along you are on your project but Id put little chunks of coin aside, even in a savings account, and let it slowly ad up. Then see what you can do
Regards, FORCON
S/F or Best Regards,
FORCON8541
FORCON8541
Has thanked: 0 time
Postby Thedude1973 » 11:45 pm Jan 04 2013
So, there is a 91 KDX 200e rolling chassis for $250. It needs a motor. I found an h complete motor for 350. I'm not 100% sure the h motor will just bolt on though.
Dude...
Thedude1973
Has thanked: 0 time
Postby rbates9 » 12:25 am Jan 05 2013
Thedude1973 wrote:So, there is a 91 KDX 200e rolling chassis for $250. It needs a motor. I found an h complete motor for 350. I'm not 100% sure the h motor will just bolt on though.
Does the 91 have an engine or is it missing completely?
The cases of an E and an H are pretty close to the same so the engine will bolt in. The head on an H has two head stays so you may have to cut one off to get it to fit.
Images: 1
Has thanked: 0 time
Been thanked: 4 times
Postby Thedude1973 » 01:43 am Jan 05 2013
http://denver.craigslist.org/mcy/3522614358.html
This is the bike. Pull the trigger?
Dude...
Thedude1973
Has thanked: 0 time
Postby dfeckel » 07:48 am Jan 05 2013
Tough call on that bike. The pictures don't show the tank, plastic or seat, which you would want to be in usable condition for that price. If the motor actually has a new bottom end and just needs a piston and the sleeve installed, then this could be a nice basis for your project. i'd be willing to bet that the power valves are trashed, which will add $125-150 to your rebuild to get right. Then they''ll probably break in about 40 hours of running any way. :( If you can live with pulling the top end every 40 hours to replace the KIPS sub valves (this has been my experience on my E hybrid), or riding a bottom-end-only 200 with broken KIPS (which has been my experience for the last two rides on my E Hybrid), then go for it! If you want the full KDX experience, I'd pick up the H motor to put in that chassis.
David Eckel
dfeckel
Has thanked: 0 time
Postby Julien D » 09:30 am Jan 05 2013
A member here at some point installed an H series cylinder/head on an E series bottom end. It also required the clutch cover and kips actuator rod from the H. Just something to think about if the troublesome kips valves are an issue.
Images: 7
Has thanked: 47 times
Been thanked: 122 times
Postby Thedude1973 » 09:35 am Jan 05 2013
dfeckel wrote:Tough call on that bike. The pictures don't show the tank, plastic or seat, which you would want to be in usable condition for that price. If the motor actually has a new bottom end and just needs a piston and the sleeve installed, then this could be a nice basis for your project. i'd be willing to bet that the power valves are trashed, which will add $125-150 to your rebuild to get right. Then they''ll probably break in about 40 hours of running any way. :( If you can live with pulling the top end every 40 hours to replace the KIPS sub valves (this has been my experience on my E hybrid), or riding a bottom-end-only 200 with broken KIPS (which has been my experience for the last two rides on my E Hybrid), then go for it! If you want the full KDX experience, I'd pick up the H motor to put in that chassis.
For sure, I'd absolutely use a RB modded h motor. As long as that suspension (rear) is sufficient, I'll be finding kx forks for the front. If the frame and master cylinder are good I hope to be on the right path at least.
May all be for not. The guy stopped responding and I'm not sure the status. We'll see.
Dude
Sent from my SPH-L710 using Tapatalk 2
Dude...
Thedude1973
Has thanked: 0 time
Postby Thedude1973 » 11:42 pm Jan 05 2013
Is there a secret for being able to view my private messeges? I get emails saying I have messages, but says I'm not authorized to read them.
Dude...
Thedude1973
Has thanked: 0 time
Postby Deseret Rider » 01:22 am Jan 06 2013
Dude-----I've sent you a private message------sounds like you didn't get to read it -----You will be most interested in it---and I'll repeat it here for you if you aren't able to get it up. Let me know
The Duck of Deseret (Deseret was Utah's first name)
Deseret Rider
Has thanked: 0 time
Been thanked: 2 times
Postby Deseret Rider » 01:33 am Jan 06 2013
Thedude1973 wrote:Is there a secret for being able to view my private messeges? I get emails saying I have messages, but says I'm not authorized to read them.
On the message which you get in email which tells you that you have a private message----is there not a link somewhere in that message which you can click on and which will then open the message for you? I had sent you a PM which you would be most interested in. You may email me at rt_rydr@Yahoo.com if you like and I'll get the message back to you that way-----
Deseret Rider
Has thanked: 0 time
Postby Thedude1973 » 01:53 am Jan 06 2013
On the message which you get in email which tells you that you have a private message----is there not a link somewhere in that message which you can click on and which will then open the message for you? I had sent you a PM which you would be most interested in. You may email me at rt_rydr@Yahoo.com if you like and I'll get the message back to you that way-----[/quote]
Yea, I did click the link but no luck. I went ahead and emailed you.
Dude...
Thedude1973
Has thanked: 0 time
Postby rbates9 » 08:48 am Jan 06 2013
You have to be a supporting member to use the PM's.
Images: 1
Has thanked: 0 time
Postby Thedude1973 » 11:49 pm Jan 06 2013
rbates9 wrote:You have to be a supporting member to use the PM's.
I want to contribute. What's the process as far as typical dollar amount. And its it PayPal?
Dude...
Thedude1973
Has thanked: 0 time
Postby Julien D » 07:48 am Jan 07 2013
viewtopic.php?f=98&t=12076
Images: 7
Postby ukkdx200 » 07:59 am Jan 07 2013
If I were in your position I would just open a new bank account and add to it little by little so you only spend the 1500 and not 3000.
ukkdx200
Has thanked: 0 time
Postby Thedude1973 » 06:06 pm Jan 07 2013
Did the $21 level just now. Tmilow@yahoo.com. Forgot to include my user name in the comments.
Dude...
Thedude1973
Has thanked: 0 time
Postby Thedude1973 » 12:33 am Jan 08 2013
http://fortcollins.craigslist.org/mcd/3524634515.html
Hopefully going tomorrow afternoon. If he'll take a bit less than he's asking, I may be able to stretch the budget just a bit.
Dude...
Thedude1973
Has thanked: 0 time
Postby ukkdx200 » 07:33 am Jan 08 2013
looks like a better plan! are you going to take someone with you? if possible you should as you will just be thinking mmmmmmmmm bikkkkkeeeeeee!!
ukkdx200
Has thanked: 0 time
Postby scheckaet » 10:52 am Jan 08 2013
both tires look really worn out.
front end looks like it might be leaking (lift the boot and inspect seals for oil and crude)
Ask him if the piston is stock or not (see newb thread in my sig)
If he's willing to go down, that could be a deal.
good luck
02 KX 200 hybrid: RB head and carb :prayer:
DRZ 400 SM :supz:
bike build: viewtopic.php?f=111&t=8245&hilit=bike+stable
bike profile viewtopic.php?p=30709#30709
newb info: viewtopic.php?f=77&t=12457#p117919
jetting guide: viewtopic.php?f=105&t=1156
Images: 0
Has thanked: 2 times
Been thanked: 6 times
PreviousNext
Return to KDX General Q&A
Who is online
Users browsing this forum: Bing [Bot] and 4 guests
cron
