Runs Like Trash Just Before Powerband
Re: Runs Like Trash Just Before Powerband
Indeed, he did come back. Seems much more well behaved this time. Virtually silent, in fact....
rbates9 wrote:Sounds like the power band might be stretched out. It happens with age. Try tightening it up to take the slack out, or you may just need to get a new power band for it all together. Try ebay if you do. You might be able to pick up a good used one.
shut the heck up....this error for real? Tell me its not guys......Roadhazardguy wrote:Sounds like the "Repair Manual Error", It tells you to put the two valves in on the wrong sides.
Yes, there is a manual misprint that tells you to put the subvalves in incorrectly. It's pretty obvious whether you have them in correctly when you look up the exhaust port while moving the KIPS shaft.
