No start after sitting for 3 Weeks?
amstel78
Post by amstel78 »
Going to drain gas out of the carb tomorrow plus pull the plug and check for spark. Bike was running well before I went on vacation. I tried to start it the other day with no luck. Anything else I should check?
Sent from my SGH-T989 using Tapatalk 2
amstel78
Re: No start after sitting for 3 Weeks?
Post by amstel78 »
Just checked the plug. Got a nice spark so I'm thinking bad gas or something got gummed up in the carb?
Dekon
Post by Dekon »
My guess would be the carb.
dfeckel
Post by dfeckel »
Was the plug fouled? If so, you could have had a leaking fuel valve or float needle that allowed a bunch of fuel into the bottom end. You might want to kick it a bunch with the plug out and the exhaust off to clear it all out and then try to start it with a new plug.
David Eckel
marrk_us
Post by marrk_us »
Happened once to me. Drained the carb, gave a quick shot of carb cleaner up the main jet while working the throttle. Fresh gas and it ran fine. Sometimes it seems you get some bad gas and it seems to gum up when sitting quicker then at other times.
amstel78
Post by amstel78 »
Plug wasn't fouled. I even tried a new plug and kicked a bunch of times. When I took the new plug out, it was still dry which leads me to think it's not getting gas from the carb. I haven't had time to drain and clean the carb yet; I'm hoping to have an opportunity to look at it this weekend.
I normally put Stabil into everything that runs on gas if it's going to sit for a while. I don't know why I forgot to do the same with the KDX. Stupid me.
fuzzy
Post by fuzzy »
Shouldn't need stabil for 3 weeks. 2T oils generally stabilize fuel anyway.
