torque wrench adaptor for cylinder base nuts
Posted: 02:15 pm Aug 21 2012
by pumpguy
I want to use a torque wrench to tighten the cylinder base nuts on my KDX 200 H series. I could probably do it with an open end crowfoot but don't want to risk rounding off the corners of the nut. It seems to me what is needed is a 12mm 12 point box end crowfoot wrench. I tried a 12mm flare nut crow foot but there's not enough clearance and it won't fit. Does anybody know if a 12mm box end crowfoot is even available? I couldn't find any. How do "those that know" use a torque wrench on these nuts?
Re: torque wrench adaptor for cylinder base nuts
Posted: 03:36 pm Aug 21 2012
by Julien D
Posted: 03:45 pm Aug 21 2012
by pumpguy
Well I'll be darn! I never knew anything like that existed.
THANK YOU!
Posted: 05:25 pm Aug 21 2012
by rbates9
I bought a MAC 12 pt adapter for a lot more money...
But that is just what you need. Keep in mind that you will need to adjust the torque setting of the torque wrench to accommodate for the added length.
Try this
http://www.belknaptools.com/support-lib ... alculator/
Posted: 09:02 am Aug 22 2012
by Julien D
The little motion pro tool comes with a conversion chart.
Posted: 10:53 am Aug 23 2012
by Brian
I bought that Motion Pro adapter years ago and I like it.
Posted: 12:39 pm Aug 23 2012
by fuzzy
I should probably get one of those. I've always just used a wrench with my calibrated human arm
They need to be tight, and the same more than being a specific value....Never had a problem.
Posted: 07:32 pm Aug 23 2012
by paulkdx220
a simpler way to torque it without using the formula is to turn the adapter perpendicular to the torque wrench and use the specified torque value. this puts the box-end or crows-foot part of the adapter in the same plane as the dive of the torque wrench . it's an acceptable industry practise in aviation maintenance.
