Solid vs Rubber Mounted Upper Clamp
I was curious if there are downsides to the solid upper clamp like the one Fredette sells to replace the stock rubber mounted one on the KDX’s. I bought a KLX300 in February that I am planning on dual sporting and it has a solid clamp on it. Maybe it is just the larger forks on the 300 but it seems much more solid on landing from a jump than my KDX does. Has anyone changed from the rubber to a solid type and noticed a big difference? I am using Pro Taper Big bars and I assume they will take more of a beating with a solid clamp but I would think they are up to it.
Thanks
Thanks
2000 KDX 220
Re: downside
Arm fatigue/pump due to excessive vibration.
Yeah...a piece of metal will be more 'solid' than a piece of rubber/plastic. After 6-8 hours in the woods, I appreciate my iso/mounted bars.
...I do after five minutes, too!!
Disclaimer: I've never tried metal cones or replaced my top clamp with 'standard' pedestals. I have tried high durometer cones from Scotts. Took them out after one ride.
- mattR
I have the Scotts high density bar cones and the FRP one piece top clamp. Never had vibration issues or arm pump before or after the change. Lucky I guess, but the bars stay put now. With the stock set up the bars got pushed back and/or twisted with the majority of my crashes. Another one of those things you have to be willing to experiment with or find a buddy with the set up you want to try.
97 KDX 220
Yep...the stock setup will get your bars twisted, tweaked and otherwise wonky if you look at 'em sidewise.
A one piece top clamp resolved that problem for me...with oem cones.
Pick your poison!
Pick your poison!
- Colorado Mike
Re-reading the first post...'..solid upper clamp like the one Fredette sells to replace the stock rubber mounted one on the KDX’s.'
I prolly misunderstand something???
'upper clamp' in this case means the fork clamp? With itegrated bar pedestals? Or is 'upper clamp' the handlebar clamp? ...but that doesn't replace the bar posts.
Fredette sells both, I believe. I could go LOOK...but I'm busy...
I don't think replacing the rubber cones with solid ones was the point....
Rod???...
Rod???...
My 92 was solid mount and the 95's are iso... I really can't tell much of a difference between the two.... By that I mean I don't get any impact soreness and armpump is the same as far as I can tell.
For me, I don't think it would make much of a difference other than I kinda like the solid feel of the solid mounts because I can tell what's going on up there...
- m0rie
I'm with Inda on this one. I had solid mounts on to start with on my 89 and switched to Inda's 95 top triple clamp with the iso mounts and I can't tell much of a difference either. The mounts just tweak when you eat it now vs the solid mounts which don't flex.Indawoods wrote:My 92 was solid mount and the 95's are iso... I really can't tell much of a difference between the two.... By that I mean I don't get any impact soreness and armpump is the same as far as I can tell.
-Maurice
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
I have the One Piece Upper Handlebar Clamp. No vibration problems and it does assist with keeping the bars straight in the rubber mounts when you take a fall.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
