How do identify which carb I have on my 220r
Posted: 03:48 pm Jul 21 2012
by cohawi
How do I post a photo of my bike
Posted: 04:24 pm Jul 21 2012
by cornishwrecker220
the only way to identify is to remove the carb & measure the INNER diameter (where it mounts to reed block side) a 200 is 35mm a 220 is 33mm ...jetting will vary depending on how the bike is set up ..std 200 carb ( jetting ) is very rich on the 220 i run a 42 pilot & 155 main, the needle is that from my 220 2nd clip from the top...if the 200 carb is off an older model 1988-1994 the slide will have a leaner *6 cutaway.
Posted: 01:15 pm Jul 22 2012
by cohawi
What carb do I have is there any no.
Posted: 01:29 pm Jul 22 2012
by cohawi
Posted: 01:45 pm Jul 22 2012
the carbs are identical to look at...there is no I.D numbers on either.. they are bored different, again 33mm or 35mm is the only way to know.
Posted: 01:49 pm Jul 22 2012
by cohawi
Thank you
Posted: 01:54 pm Jul 22 2012
by cohawi
cohawi wrote:How do I post a photo of my bike
Re: How do identify which carb I have on my 220r
Posted: 03:55 pm Jul 22 2012
by diymirage
best way to do it is use a site like photobucket
you just make an account and upload the pictures
(i use the wifes phone and email it directly to the site)
then it makes up a link you can post and it will look like the actual photo
