Picked up a used frame
Posted: 08:45 pm Jul 16 2012
I bought a bunch of parts on eBay and one of them happened to be a complete 1989 KDX200 frame. I'm picking it up on Saturday but have a question about the right engine guard (the one that protects the water pump but is on the left side of the frame in the photo below). In the photos it appears bent upwards and I think might come into contact with the water pump housing. If so, I suppose I could have someone cut it off and reweld it back on at the proper angle. Either way, I only paid $39.00 for the frame so I'm not too concerned.
Here are a few pics; perhaps you guys could tell me if it's bent too far or if it's supposed to be like that? The right engine guard on my KDX200 in the garage I believe is level to the left side.
FWIW, I also picked up a complete odometer drive and cable, triple clamps and stem, engine kill switch with wire, crank case halves (left and right side with bearings), cylinder head, front dampers in excellent conditions with perfect OEM seals and boots, clutch perch with lever, and rear brake lever. Together with the frame, I spent about $140.
