1989 water pump seal
Posted: 09:42 am Jul 16 2012
by Dekon
I found the following on another site, does anyone know if this is correct? Can I install the 90-94 seal and does anyone know if it is a drop in fit?
"They also had a problem with the waterpump seal going on the 89,so for 90-94 they installed a back-up seal,you can upgrade to this."
Posted: 10:04 am Jul 16 2012
by SS109
As far as I know, yes, you can use the later seal. It is not a "drop-in" fit. You have to seat it just like any other seal.
Posted: 10:58 am Jul 16 2012
by KDXrider1989
It works fine on mine, I have a later model seal
Posted: 11:39 am Jul 16 2012
by Dekon
SS109 wrote:As far as I know, yes, you can use the later seal. It is not a "drop-in" fit. You have to seat it just like any other seal.
Sorry, no, I know it is not just going to "drop-in", what I meant was, does the case or WP shaft have to be modified.
Posted: 11:40 am Jul 16 2012
by Dekon
KDXrider1989 wrote:It works fine on mine, I have a later model seal
Do you remeber what seals you needed to order?
Do I just order the 1989 seals and then add the '91 part in this diagram?
http://www.ronayers.com/Fiche/TypeID/26 ... Cover(2_2)
Dang, the link will not work.
Posted: 12:13 pm Jul 16 2012
by SS109
No mods to the case at all. I don't know how they expect you to fit two seals in there though as I couldn't do it. There just isn't enough room to fit both without one not being fully seated. I just used part # 92049-1366 (92049D on the diagram) and it has been working fine. I still have the # 92049-1359 seal sitting in a box.
