I just want to see what others would do. I picked up a1989 for $200 off of CL. The bike is compete and is in fairly good shape. The plastics look real good and the seat is like brand new. The only thing is I never got to start it as the kicker was only engaging like 1 out of 10 times. It has spark. I also knew that the water pump seal needed to be replaced as the tranny oil was white/gray colored. From my other post, my son pulled the KIPS shaft out and the LH valve is not working now. So, what I am asking is this:
Would you just pull the whole bike apart now(seeing as how I have to take the motor out to repair the KIPS), or would you just pull the motor and fix the KIPS and kicker and make sure it runs?
One other thing, I pulled the kicker mechanism apart yesterday and all of the parts look great. The ratchet gear and the kick gear seem fine, the teeth show very little wear. I can not figure out why the kicker was only engaging sometime.
Sorry for the long post.
What would you do?
What would you do?
If you have the time and money, go ahead and go through the whole bike. You are sure to find other things that it needs, like swing arm bearings, fork seal, ect..
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
What would you do?
Wow, great deal (or should I say steal?) on the bike! Like David said, I would go through the whole bike. Check all your bearings, probably needs fresh fork oil, etc. Take your time and we are here to help if you need us.
Re: What would you do?
Every time I pick up a bike it always goes through a full maintenance, from wheel bearings to handlebars
What would you do?
What were your expectations when you bought it? Is this a bike you are looking to resell or keep forever or somewhere in between? Do you mind spending a ton of money on it?
What would you do?
Sorry I should have been more specific, should I see if I can get it running properly first, meaning fix the KIPS and the kicker, putting the motor back in the frame and see if it will start. Then go through the whole bike. Or, tear it down to the bare frame, going through it and hope it runs in the end.
What would you do?
I suggest getting it to run first. Why rebuild forks / shocks / bearings / anything on a bike with an engine that won't crank? That is my suggestion.
- rbates9
What would you do?
before you you tear it all apart check the compression and see what you have. Then pull the engine apart.
