piston
piston
If you go to a site like www.rockymountainatv.com or www.motosport.com and put in your information you should be able to find an OEM one or you can try ebay for one. I believe that you can only use pre 85' pistons in your kdx.
Re: piston
85 & younger are discontinured parts.
piston
www.kawasaki.com, then look under Owner Info, then Parts Diagrams and use the menu system to select your model.
