kdx 200 carb problems
Posted: 09:01 am Jun 07 2012
by woodselec
I have a 2002 kdx 200 that i can not get dialed in. I have a fmf desert,boysen 607's,modified air box lid.
Jets are 155 main,42 pilot, air screw @ 1.5 and jd red needle. The bike loads up every where but w/o throttle. From a dead stop bike will not clear out untill 3rd gear and the power comes in so strong it will come out from under you. Ive been through the jetting sticky on here with no results. the only thing i havent done is a w/o throttle chop becouse i have to wait till the hay is cut. I bought this bike in april totally stock it had been setting for over 2 years with the old gas left in. I have cleaned the carb 4 times but am wondering if i may still have some gunk left in there somewhere.
need all the advice i can get!!
Posted: 10:09 am Jun 07 2012
by fuzzy
Clean air filter and fresh plug I take it?
Posted: 10:45 am Jun 07 2012
by woodselec
Yes new plug clean air filter and running 40:1 yamalube 2r 94 octane pump gas. my elevation is 3000 ft if this helps. I was thinking about droping my main to 150 but would like to da a plug chop on the 155 first.
Posted: 06:19 pm Jun 09 2012
by woodselec
Here we go again!
Yesterday I was determined to fix this bike so i warmed it up good and started the jetting routine.I adjusted the pilot circuit and got some progress so i then moved the clip to mid position and redone the pilot circuit. bike ran great i could lug around, coast down hills then crack open the throttle and the bike would come to life. So today jump on the bike and it runs like crap again. I thought maybe it will straighten out when it warms up but it didnt. same thing as always 1/4 to 3/4 throttle sucks.I have repeated this process over and over for the past 2 months.
Open for suggestions
Posted: 09:55 pm Jun 09 2012
by K D
I am not familiar with JD needles but at 3000ft elevation 155-42 might be a bit rich, Im running 152-40 at sea level.
Posted: 01:58 am Jun 10 2012
by Mr. Wibbens
make sure your kips is working
and clean the carb real good, make sure it's not a fuel problem
Posted: 03:37 am Jun 10 2012
by kyledsmith87
Check the stator coil when hot! Half dead mid-throttle was the 1st symptom of mine going. Should read between 300-450ohms
Posted: 09:22 am Jun 10 2012
by woodselec
I will check the kips and stator coil today and post results.
Thanks for the info!!
Posted: 07:31 pm Jun 11 2012
by woodselec
Ok i checked the kips and its working just fine. I pulled the fly wheel cover off and it had some gas inside the cover is this normal ?
Posted: 07:34 pm Jun 11 2012
by rbates9
Gas or oil in the flywheel side = you need crank seals and bearings.
Posted: 07:44 pm Jun 11 2012
by woodselec
The amount of gas was not very much (just a couple of drops) is this something that can be put off untill this winter or does it need to be done imediately. I was planning on a R&B head mod this winter anyway.
Posted: 07:56 pm Jun 11 2012
by rbates9
Leaking crank seals will make the bike run unpredictably. If you do put it off than it wouldn't be a bad idea to keep an eye on the leakage. Also it could be sucking more air in than leaking gas out and the transmission side could also be sucking air. You may have just found the cause of not being able to get it dialed in.
Splitting the cases isn't that bad and could be done on a rainy day.
Posted: 08:15 pm Jun 11 2012
by woodselec
Well sounds like a good place to start I guess i need to invest in a fly wheel puller.
Thanks for all the advice
