Crank seals. Do I need to split cases?
Posted: 10:22 am Apr 17 2012
by Terrence Sprocket
I'm pretty sure I need to split the crankcases to install new crank seals on my E series 200. I'm just wondering if any one knew of a way to do it without splitting them, or is it the only way?
Thanx.
Posted: 11:04 am Apr 17 2012
by Slick_Nick
Split em.
Posted: 11:12 am Apr 17 2012
by Tedh98
You'll also want to replace the crank bearings.
And if that E is all original, I'd replace all the other bearings in there while the cases are apart. If you do all that, you won't have to split it for a long time.
Posted: 12:46 pm Apr 17 2012
Ok. What other bearings are u referring to? The tranny shaft bearings, and clutch bearings, etc?
Posted: 08:42 pm May 14 2012
by Thack
I think he's talking about the crank rod bearing and the crankcase bearings.
