questions about the power valve.
dnovack
Post by dnovack »
i got another cylinder for my 91 kdx 200 and i need some advice on how to set the timing on the power valve the correct way? also off topic what size bars are on a 91?
Fletch
Post by Fletch »
7/8 bars on the 91.
The timing is supposed to have the main valve and sub valves closed when the rod is in and all of them open when the rod is pulled out/away from the cylinder. There are dots on top of the gears of the sub valves and the idler gear to line it all up but you can figure it out by how it works.
Really you need a manual.
Fletch
89 kdx 200 with 99 rm125 forks
dnovack
Post by dnovack »
I do have one just had a few questions on it. I was just alittle confused on how it was worded and didnt wanna mess anything up.
91-kdx200
2001-gsxr750 (bored and stroked)
2001-jeep wj
Fletch
Post by Fletch »
Ok, great.
I used the diagram to roughly get there. Then I started with the valves all open (rod out) then slid the rod shut and made sure everything was closed fully. You'll know when it's right.
Fletch
dnovack
Post by dnovack »
Ok thanks for the advice. What are ur takes on pro x pistons? I wanna put new rings in bit i can get a piston rings bearing and gaskets for $120.
91-kdx200
2001-jeep wj
Fletch
Post by Fletch »
I like the forged wiseco's because they're stronger and I've had a cast oem blow up on me. but that piston was way way overdue and I should have known better.
I will say that any new piston is better than an old one and if you're wondering at all when you see it then change it.
A new cast prox will be just fine.
Fletch
dnovack
Post by dnovack »
Ok i think ill get it. Im not going to run the bike real hard. I was thinking a new piston would b better than a beat used one with new rings.
91-kdx200
2001-jeep wj
rbates9
Post by rbates9 »
Pro x = oem.
dnovack
Post by dnovack »
can you use pro x rings on a oem piston?
91-kdx200
2001-jeep wj
pro-x manufactures the OEM pistons, which is what rbates meant when he said pro-x = oem. There is no difference. So, yes, you can use pro-x rings on the OEM piston.
dnovack
Post by dnovack »
ok thank you.
91-kdx200
2001-jeep wj
