rear brake spring
canamfan
rear brake spring
Post by canamfan »
Guys can you tell me where the rear brake spring attaches to the frame? Mine is missing the manual shows the spring and there is a peg on the brake pedal for it but i don't see anywhere on the bike where it attaches. I've searched for a post on this but no luck
thanks Steve
wbdisco
Post by wbdisco »
there is a hole right above the lever, it is small but it is right where you would think it should attach
2000 KDX200(mine)
Polini X3(daughter)(FOR SALE)
TRX70(other daughter)
Big Bear 400(wifey)
1969 M35a2 (Deuce and a 1/2)
canamfan
Post by canamfan »
I found it i think it's where the swingarm bolt comes thru I couldn't see it cause of the black plug in the hole. thanks
Arkmage
Post by Arkmage »
is this spring really needed? mine fell off and got lost somewhere.
KarlP
Post by KarlP »
It is kind of needed but you can do without for a while.
I like to use a spring that is quite a bit stiffer than stock. I tend to leave my toe on my brake and without a stiffer spring I'll end up riding the brake.
'08 KTM200xc
KX100 for the boy
Arkmage
Post by Arkmage »
Fair enough. I'll dig around in the garage and see if I can find something suitable. I think an old timing belt tensioner spring from one of the miatas would probably fit.
