I pulled my exhaust valve apart to send the cyl out for Replating, and I found the gear that bolts to the LH side of the shaft has a broken tooth at the very end.
Anyone have a spare they would like to get rid of? I found them new for $65, so I figured I'd try to source a used one. It would probably be fine the way it is, but I'll most likely replace it anyway.
Thanks
KIPS Gear
- OLHILLBILLY
From what I understand , it will work fine with a tooth missing on either end. But your best bet for a cheaper replacement would be to watch Ebay.
Be sure and remove the little pipe thread plug on the front of the cylinder before you send it off for replate. If you don't, they will, and you won't get it back. Seen many stories about that happening.
2004 KDX 200.. Coupla mods
2009 KX250F.. Track Star
If you mean the plug with the doing in it, got that. If not, I may be looking for a new one as I've already sent it....OLHILLBILLY wrote:From what I understand , it will work fine with a tooth missing on either end. But your best bet for a cheaper replacement would be to watch Ebay.
I've been checking eBay with no luck. I'll probably try it as is and see what happens.. Worst case I can change it out afterwards.
- scheckaet
i've run mine for the past 4 years like that. save your 60 bux and go ride
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
