worm top ?
l2f
worm top ?
Post by l2f »
Hello,
I am wondering how to detect a worm top, I'm reading (http://justkdx.dirtrider.net/printcarbtuning.html) about jetting the carb of my 2002 kdx220
Thank you in advance for your help
l2f
chkdx
Post by chkdx »
What is a worm top?
I"m guessin you mean worn top end?
Compression test would be a good place to start. Even better, if it's a used 2 stroke you picked up, go ahead and throw a new top end in it. since you ride a 220 you need to be sure there's a forged piston in there. The stock pistons are not reliable int he 220's, and if they drop a skirt, could cost you a bundle.
factoryX
Post by factoryX »
What would be average compression? Mine is currently at 140lbs
They did change the usuable compression spec a couple times. I'm not 100% sure off-hand what it is for an H bike, but my 89 manual says something rediculously like 90 - 180 usable range. AFter break in on the last top end my gauge showed 160.
(btw, i'm moving this to general Q/A as it does not relate to RB mods at all)
OLHILLBILLY
Post by OLHILLBILLY »
H model (200 anyway) usable compression range is given as 95-151psi.
2004 KDX 200.. Coupla mods
2009 KX250F.. Track Star
2007 Hayabusa.. Street Madness
l2f
Post by l2f »
juliend wrote:I"m guessin you mean worn top end?
The previous owner did it, he put a wisco.
Thanks
l2f
Post by l2f »
I will double check the compression and see with the manual. My 220 is a used one but it runs good. In the "how to jetting", before doing the jetting session you have to check the worm top end and the gas carburation level that why I ask this question.
Thanks
fuzzy
Post by fuzzy »
That's great. I'd just start jetting it. Unless damage is done due to running lean/etc the top ends on these last A LONG time.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
l2f
Post by l2f »
Happy to hear that :grin:
thank you
