Hello,
I have a kdx 220R 2002 with stock lighting coil and I have a acerbis headlight, dual mr16 lights but the lights draw 35w each so with the taillight (10w) it draws 80w too much for the stock coil. I am wondering if I am able to put 2 led lights but with which power: 2x15w + tailights = 40W or 2x18w + taillights = 46W ?
Thank in advance for your help
kdx 220R 2002 led 15W or 18W
Neither. The stock lighting coil puts out 30-35 watts max. You need to upgrade your stator or check into one of the more expensive LEDs light out there.
- diymirage
Very true. I guess I should have mentioned that since that is what I did on mine.diymirage wrote:on a side note, LEDs draw WAY less then their filament counterparts
the LED equivelant of an 1157 taillight bulb will only draw less then one watt
so replacing the taillight with a LED will prettymuch take it out of the eqaution as far as draw goes
