expensive kick starter!!
Posted: 11:27 pm Nov 22 2011
by BFD
My 96' kdx 200 kick start lever broke right next to the hinge. My god they're expensive! I welded it back together and so far it is holding up. Has anyone found an alternate kick starter, from another bike that will fit the splines? Maybe a lighter aluminum one? Thanks, BFD
Posted: 11:47 pm Nov 22 2011
by rbates9
do a search on KX kick starters. I think people use a KX 250 knuckle (the splined part) and a KX 125 lever. I belive FRP sells the set up but it is shorter than the stock kicker. But it is aluminum.
A brand new complete unit is about $90.
Posted: 12:33 am Nov 23 2011
by BFD
Hey, thanks! Went to the FRP site. $89, small, and alum. Thats what i'm looking for!
Posted: 12:45 am Nov 23 2011
by bcdonyo
I find the shorter FRP makes it start easier.
Posted: 11:35 am Nov 23 2011
by dfeckel
I ran a KX 250 knuckle with a KX 125 lever, sadly for just one day. It fell off because I didn't locktite the retaining nut. It hasn't been found yet. The FRP lever looks as if it uses the KDX knuckle, which is nice. Also, it looks as if the KX 500 uses the same knuckle as the KDX, so you might be able to use one of those kickers, too.
Posted: 12:20 pm Nov 23 2011
by OLHILLBILLY
That KX250 knuckle/KX125 lever set up isn't cheap either. Figured it up from Ron Ayers a while back.. $125.60 total.
If your knuckle is still in good shape, the FRP lever is definitely cheaper.
Posted: 12:25 pm Nov 23 2011
by frankenschwinn
OLHILLBILLY wrote:That KX250 knuckle/KX125 lever set up isn't cheap either. Figured it up from Ron Ayers a while back.. $125.60 total.
Flea bay is your friend
Posted: 02:06 pm Nov 23 2011
by dfeckel
They're surprisingly expensive there, too. Most Buy It Now for $50 or more. Since you have to buy two different kickers, you're still in for $100.
Posted: 05:22 pm Nov 23 2011
by swatts
Using a FRP kickstarter, no problems, I recommend it. Get yourself an autoclutch too, and kickstart less.
Posted: 08:42 pm Nov 23 2011
by hockeyboysomers
I've mentioned it before, but I just used a KX250 kickstart lever. It is on a Hybrid though. It works great and I don't have to worry about hitting the footpegs because it's too short. I think it is a from a 1999 KX250. Good Luck
Posted: 11:57 pm Nov 23 2011
by david
Service Honda has the best price on a new, factory unit. I just bought one for my '90 for about $70.
Posted: 04:39 am Nov 24 2011
by Mr. Wibbens
I prefer the stocker
Carvr has that POS one from FRP, it's always wearing out here and there, I bet he has $500 in machine shop work getting it to last this long
Posted: 12:19 pm Nov 24 2011
by bcdonyo
swatts wrote:Using a FRP kickstarter, no problems, I recommend it. Get yourself an autoclutch too, and kickstart less.
+1
Mr. Wibbens wrote:I prefer the stocker
Been runnin my FRP for almost 2 years now, no problems. Maybe the autoclucth helps as I don't shut the bike down near as much.
Who the hell is Carvr?
Posted: 12:24 pm Nov 24 2011
by Julien D
I'm using that kx250 boss / kx125 lever combo. I do like it, but I think the stocker is easier to start the bike with and less painful than slapping your foot into the peg repeatedly. I lost my stock kicker on the trail, and was able to get the bits off ebay for cheap to do this hybrid kicker thing. All in all it's ok. I might put the kx250 lever on it though, since it's still aluminum, but longer than the kx125 lever. I think my kx250 lever was a 98, not sure what year kx 125 lever i got...
Posted: 01:38 pm Nov 24 2011
by SteveWR450f
+1 on the kx 125 arm and 250 boss. Yes, its kinda spendy but its more reliable than FRP unit. i know some have had great experiences with FRP lever but I did not. i have had two different friends and one repair tech brake them. Each time FRP was great to warranty them but got tired of wondering when it was going to break.
Posted: 05:58 pm Nov 24 2011
by Slick_Nick
The KX unit is a more robust "sealed" design anyways.
Posted: 10:03 pm Nov 24 2011
by SS109
juliend wrote:I might put the kx250 lever on it though, since it's still aluminum, but longer than the kx125 lever. I think my kx250 lever was a 98, not sure what year kx 125 lever i got...
Hmm, sounds interesting. I might need something like that for my 250 hybrid build.
