I cleaned the cover before removing it. When I did, there were bits of dirt on the bottom of the reservoir. The cover was on securely.
I did a full bleed in the early spring, and there was not even a speck of dirt in there when I was done. How does this happen? Should I do a full bleed? Does the dirt cause damage? The fluid was as clear as the day I put it in there. The fluid level was proper as well.
Thanks for any input,
David
I have bits of dirt in my rear brake reservoir.
- Fatherof2
