KDX 200 Rear light not working
Posted: 08:21 pm Aug 19 2011
by kms432
I have a 2006 KDX 200 and the rear light will not work for long. I have replaced the bulb two times recently and the light will work for a brief time and then both times after a brief ride I look back and notice that its no longer working. What could be causing this?
Posted: 09:16 pm Aug 19 2011
by rbates9
Are you using the correct bulb?
Posted: 01:50 am Aug 20 2011
by kms432
rbates9 wrote:Are you using the correct bulb?
the bulb i've been using is a 12v10w. I put them in and they work for short while and then stops.
Posted: 01:23 pm Aug 20 2011
by gsa102
Does the headlight work? If it is blowing bulbs I would check the voltage at the light while the bike is revved up to make sure it doesn't go above 14V. If it does, the voltage regulator is bad or has a bad ground connection.
Posted: 05:26 pm Aug 20 2011
by kms432
gsa102 wrote:Does the headlight work? If it is blowing bulbs I would check the voltage at the light while the bike is revved up to make sure it doesn't go above 14V. If it does, the voltage regulator is bad or has a bad ground connection.
The headlight works fine. I think it still has the original bulb in it. The rear light, however, i've replaced twice and would only work for a short while and then would stop.
Posted: 03:52 am Aug 21 2011
by Brian
If you are not using an origonal style bulb made for high vibration areas you are gonna go through a lot of bulbs. The ones you buy at your automotive store are not built to withstand the vibration levels found on a motorcycle. Rev your bike sometime and watch the tail light buzz and jiggle.
Or... there could be something else wrong.
Posted: 08:44 am Aug 21 2011
by TWMOODY
Put a LED bulb in there from Auto Zone and be done with it..
